I have a 90 that is non intercooled with the stock turbo, pushing 40 lbs of boost, I really like how it runs but of course I want more. The b1 turbo started making a frinicky sound at low boost(1-3PSI) and when I let of just taking it easy you can hear it spool down over my stacks. So I am looking to do it right I want to eventually go with a s2000 turbo, and oring the head and put head studs, with all that what kind of boost numbers am I looking at before something blows a part and will the getrag stay together, I imagine with this setup you could push 60lbs of boost and somewhere in the 400-500 hp range and over 1100 ft lbs would this be correct the getrag already has over 300000 miles on it but I drive it conservatively except when someone is tailgating and they need a smoke fix or when I just have to show off to my buddies.
Would non intercooled with water methanol injection keep it cool enough or with that kind of fuel going to light the s2000 are my egts going to be outrages, I alrady see 1700 degrees but I never keep it there for more than 15-20 seconds, would water meth cool it down enough.
Finally when I am ready, do you guys know anybody in the Colorado area that will do a head oring and where I can get head studs. Also I spun my clutch in 3rd gear the other day, I was leaving a stop sign and got after it because of oncoming trafic and I dropped the clutch in third gear with about 10lbs of boost and I went no where. Its the upgraded version of carquest but I have never seen that happen. I know centerforce makes a good clutch but a diesel doesnt turn the rpms to spin the weights to get it to lock up. Suggestions?
