Walbro pump
Walbro pump
Postby jer1 » Fri Feb 16, 2007 9:12 pm
Hey guys, great site. Lots of good info. I was wondering if someone could(would) post or email me a sketch or cartoon(something I might be able to understand) of the Walbro pump setup, and part numbers, good sources. Thanks, Jer
91 W250, 6" susp. lift, 2" body lift, 36" Buckshots, Powersmoke IC, Haisleys studs and fire rings, PDR valve springs, Banks high ram, HTB2 62/14, 4"DP, Dual 5" exhaust, Bullydog boost and pyro (pre-turbo), POD's, tweaked pump, timing bump, 3200 gs
jer1
Postby wannadiesel » Sat Feb 17, 2007 9:12 am
Here's the thread I posted on DTR about my setup.
http://www.dieseltruckresource.com/dev/ ... p?t=120066
Read that and see if it clears things up for you. I'll try to sketch out a schematic of it.
Best dyno: 408/844
wannadiesel
diesel guru
Postby jer1 » Sat Feb 17, 2007 10:55 am
Just what I was looking for. Answered all of my questions, and gave plenty of food for thought. Thank you much, Jer
jer1
