pyrometer probe question
Postby mprmn08 » Tue Feb 17, 2009 5:29 pm
I just wanted to make sure but what is the best place to put the pyro probe. i know its pre turbo but do i put it towards the front or back? also is there any certain distance away from the flange i should put it or the closer the better? thanks
chris
mprmn08
Postby peobryant » Tue Feb 17, 2009 5:56 pm
I think most people place them in the exhaust manifold, near the rear cylinders. Those are supposedly the ones that get the hottest.
Postby PToombs » Tue Feb 17, 2009 6:12 pm
In the manifold, just before the turbo. Either to the front or the rear is ok. There is a web in the middle, so that won't work. ;)
Postby mprmn08 » Tue Feb 17, 2009 6:17 pm
ok i just had heard that there is a certain spot (front or rear cant remember) that is better cause it is actually hotter then the other and wasnt for sure. thought it was the rear but just wanted to make sure before i drilled a hole. thanks guys :D
mprmn08
Put it in the rear
Postby Ace » Tue Feb 17, 2009 6:52 pm
Put it in the rear. #6 runs hot. There's even a mod to route additional coolant back there. I would do it if I towed alot.
Ace
