Crossover tube.
Crossover tube.
Postby Farmboy » Mon Feb 23, 2009 8:33 am
I am thinking of fabbing my own crossover tube out of 3" stainless. I was going to bend it all one piece and weld a flange on the elbow. Does anybody happen to know the bolt pattern for the flange? Also are there any critical dimensions that I should know about?
Thanks for the help.
Farmboy
Postby Ramrod90 » Mon Feb 23, 2009 5:57 pm
The best thing to do would be to pull off your grid heater and stencil the outline onto a piece of paper. or leave it on and measure it the same way. Or trace a gasket. Also, make sure it hugs the valve cover so you don't run into any clearance trouble with the hood. hope this helps.
90 w250 LE, pump turned up, 4" turbo back, I/C conversion, 366 GS, DennyT pin, 6x18's, BHAF, soon to come... 6" stacks and built head.
Diesel is more than a fuel... it's a way of life
Ramrod90
Postby Farmboy » Tue Feb 24, 2009 7:50 am
When I go ahead with it I will do that. I had some spare time at work and was drawing it up and the truck was at home. thanks though.
Farmboy
