New Era 370 Nozzles
New Era 370 Nozzles
Postby peobryant » Sun Mar 01, 2009 10:32 pm
I know where a set of 2nd gen 370's are for sale for about $275, Could I just take the nozzles off and put them on my stock injector bodies, or is something preventing this?
I don't see why it wouldn't work, but I figure I would ask just in case.
Postby cedardiesel » Mon Mar 02, 2009 5:42 am
If I ain't mistaken you can swap tips with out a problem
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby KTA » Mon Mar 02, 2009 10:09 am
That is how I got the 370 injectors in the trailer pulling truck. It runs a nice 300rwhp and 900ft-lbs.
Postby sdstriper » Mon Mar 02, 2009 11:40 am
KTA, what pressure are your 370's set to?
sdstriper
Postby peobryant » Mon Mar 02, 2009 12:37 pm
KTA wrote:That is how I got the 370 injectors in the trailer pulling truck. It runs a nice 300rwhp and 900ft-lbs.
Is that the same set up George pulls The Ghost with?
Well, looks like I'll have some 370's pretty soon.
Thanks
Postby peobryant » Mon Mar 02, 2009 3:20 pm
Brian, did you reset the pop pressure on the injectors when you installed the 370 tips? I would think the pop pressure would be the same as a stock 1st Gen, because I'm using the same body, but I don't suppose it could hurt to get them reset. Where did you get yours reset, and about how much should it cost?
Thanks
Postby KTA » Mon Mar 02, 2009 3:56 pm
We have a nozzle tester here so I set them myself on it. I think DI charges like $30 each to clean and set a injector. Mine were about 3200psi.
Postby PToombs » Mon Mar 02, 2009 6:05 pm
I thought the 2nd gen 370's had the wrong spray pattern (angle) for the 1st gen piston? :?
Postby Richie O » Mon Mar 02, 2009 6:07 pm
PToombs wrote:I thought the 2nd gen 370's had the wrong spray pattern (angle) for the 1st gen piston? :?
You beat me to it Pete. That was my impression also.
Postby peobryant » Mon Mar 02, 2009 6:40 pm
I thought that too, but my brother said George Peterson has 2nd gen 370 tips in his 1st Gen tow rig, and it does just fine, and apparently Brian has the same thing, so I guess it doesn't matter too much. Plus I'd rather pay $275 and no injectors core charge than $425 plus core charge.
Postby peobryant » Tue Mar 03, 2009 7:47 pm
KTA wrote:We have a nozzle tester here so I set them myself on it. I think DI charges like $30 each to clean and set a injector. Mine were about 3200psi.
Well, Brian, you want to do another set? (I'm serious by the way, I don't want to have to pay that much.)
Postby KTA » Tue Mar 03, 2009 9:13 pm
I can't clean em but if you bring em by I can swap and set them.
Postby peobryant » Tue Mar 03, 2009 9:37 pm
KTA wrote:I can't clean em but if you bring em by I can swap and set them.
Alright, if I go with the 370's I will swing by.
Thanks.
