parallel turbos
parallel turbos
Postby fatty » Wed Mar 18, 2009 8:04 pm
would it be possible to run two turbos-say an he341 and stock h1c-on a 12 valve with one in the stock position feeding into the intercooler and the other with a crossover tube non intercooled? not compounds but with the he341 on the manifold and with a hotpipe to the h1c? the he341 would go to the intercooler like normal and the h1c would go over the valve covers into the intake manifold.
Postby dpuckett » Thu Mar 19, 2009 5:41 am
The problem with parallel turbos is getting them to feed evenly. Even with 2 identical turbos, you wouldnt always get identical airflow, much less with 2 different turbos. I think there would not be anything to gain, and may even lose some with your set up. I like the fact you're thinking outside the box, though.
Daniel
Postby KTA » Thu Mar 19, 2009 2:45 pm
Parallels can work when sized and valved properly. Look into the Seatek racing diesels they use parallels with good success. That being said I see no gain to running baby turbos like what you are talking about.
