by Richie O » Fri Mar 20, 2009 5:39 pm
Philip runs 6x18's with stock fuel settings. He does not have 400 hp but it proves you can run a big set of sticks as long as you know a stock lift pump and a stock size turbo is not going to be happy with the fuel screw turned in. I run 297 hp on my non i/c injectors ( 4x12 ). There is no reason why I could not run the same hp on 6x16's and have the current fuel lift pump and turbo. I suspect I would have to actually turn fuel screw out some to keep the same hp If I did change to a bigger holed injector. If I am wrong ,,,, SORRY.
