Had to clearance the fire wall a little with the sledge hammer for the 2nd gen 4" HX40 style down pipe to fit
The expandit exhaust I got from Diesel Dawgs has a 3-1/2" Down pipe. Since I used the 4" 2nd gen I cut off the adapter as well as a short piece of the down pipe and joined them with a short piece of flex pipe.
Then it was just a matter of putting the pieces together. The kit went together VERY easy. It fits PERFECT!!!
Here is the 4" pipe going past the Transfer Case
I used band clamps (you can see them in the flex pipe pics) instead of the U-Bolt clamps that come with it. this will make it easier to take apart in the future. I used the u-bolt clamps that came with it for the hangers.
I used the stock hanger for the tail pipe. I just drilled a hole in the pipe and put the bolt through.
Again... VERY smooth install!
I would HIGHLY recommend this system to anyone who wants a better exhaust for there truck! Even If you have a stock turbo I would still get this kit. I really feel the 3.5" Downpipe wont hold you back anymore then the stock turbo will. Then when you buy your s300 or HX40 turbo they usually come with a 4" downpipe or you can do like me a get a used one for under $100.
