Horus wrote:Say you don't want to remove the collar. Can decent power gains be made turning the screw in till the collar bottoms out or slightly before?
Is removing the collar and turning the screw to full fuel a good idea on a truck that will do a lot of towing?
ford69557ci wrote:It is on the back of the injection pump closest to the engine block. It may have a plastic cover over the screw and it will have a jam nut on it also. There is a metal colar that will need to be removed in order to get max fueling from the fuel screw adjustment.
Richie O wrote:My 93 was almost to the collar when I busted off the anti tamper tin cap. I pulled the screw out and beat off the collar. I worked my way to bottomed out 1/2 turn at a time with no runaway. It increased max boost to 32 psi with the 60 mm GDS compressor. I saw 1200 max temp.
Every pump is different for sure.
'91 Cummins wrote:
Richie, you get that '93 on the road yet? Have you driven it with the 6X.016's?
Its in need of body work and paint but it's on the road with the 6X16's.
And where have you been?
Bad93Cummins wrote:Will turning the fuel screw 2-3 turn's will that hurt gas mileage or hurt my old motor?
Users browsing this forum: No registered users and 78 guests
