Turbo
Turbo
Postby Bad93Cummins » Fri Apr 10, 2009 5:53 pm
I saw this on a website i have found numerous parts for my 93 cummins and came acroos this turbo housing, http://dieseldawgs.com/product_info.php ... cts_id=223
Where do you get the shaft, and everthing else to hook it up to my 93 Cummins? also is it worth the money?
Thanks
First time cummins/deisel owner sorry for all the questions and post's.
Bad93Cummins
Postby gear jammer 91" » Fri Apr 10, 2009 6:14 pm
That turbine housing would replace the turbine housing on your turbo. You would not need to purchase any other parts for the turbo, other than gaskets. You would probably be better off trying to find a used turbo like an hx-35, or the turbo off of a common rail truck, as long as it's not a variable geometry model. An upgraded turbo will give you quicker spool up and a larger volume of air, which will allow your engine to make more power and push more boost when the time comes.
01 LB7
gear jammer 91"
Postby Bad93Cummins » Fri Apr 10, 2009 7:02 pm
So that turbo housing is not worth it?
Bad93Cummins
Postby RSWORDS » Sat Apr 11, 2009 7:52 am
It would be an improvement over the stock one for spool up. Are you looking for a compressor housing to dao a 60mm upgrade? That housing is the exhaust side.
RSWORDS
Postby gear jammer 91" » Sat Apr 11, 2009 9:20 am
It's not that it's not worth it, I spent money on a turbine housing upgrade right after I bought my truck. It didn't do as much as I had hoped. If you are going to leave your truck stock and want a little better spool up it wouldn't be bad, but if you could come up with the money for a whole new turbo new or used, I would recommend doing that instead.
01 LB7
gear jammer 91"
Postby Bad93Cummins » Sat Apr 11, 2009 1:06 pm
I don't plan on much esspeiclly sence this motor has about 35#,### on the motor and 50,000 on replaced tranny. I just thought cold air intake, some 60hp injectors, fuel pin, 4" straight pipe and maybe 3200 spring, not sure don't want to hurt my reliabiltiy and mpg.
Bad93Cummins
Postby oilcan64 » Sat Apr 11, 2009 1:11 pm
you would definately see faster spool, but that is way overpriced...like the other guy said a used hx35 would do fine but here is a site for the same turbo housing but cheaper
http://www.gillettdiesel.com/turbocharg ... des-2.aspx
shop around and check the classified before you spend any money
justin
1992 - w250 - 5 speed - LE - Reg. cab - 8' bed - minor pump tweaks - srw - ic
KDP & Killer Bolts killed
Saving for body work!
oilcan64
Postby Bad93Cummins » Sat Apr 11, 2009 5:59 pm
oilcan64 wrote:you would definately see faster spool, but that is way overpriced...like the other guy said a used hx35 would do fine but here is a site for the same turbo housing but cheaper
justin
Any of those tubro's be good for what I want to do?
I just want alittle more kiddy up, little more performance an little smoke here and there but try and keep the good mpg.
Bad93Cummins
Postby Bad93Cummins » Sat Apr 11, 2009 6:01 pm
something like this yall talking about, a stock tubro with less miles?
http://www.cumminsforum.com/forum/1st-g ... miles.html
Bad93Cummins
Postby cell » Sat Apr 11, 2009 11:55 pm
If you can find a cheaply priced HX35 or WH1C, otherwise save up for an S300.
cell
Postby MMeier » Sun Apr 12, 2009 9:52 am
Bad 93, where are you located? I'll sell you my stocker with the 16 housing already attached to it for $325.
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Users browsing this forum: No registered users and 78 guests
