32K INSTALL ???
32K INSTALL ???
Postby CAJUN 93 » Tue Feb 27, 2007 12:41 pm
i installed the 366 spring in my truck sunday. when i un-did the throttle lever on top of the pump, it jumped up and off before i had a chance to check the tick marks. after the spring swap (interesting to say the least). i turned the shaft about where i thought it should be and cranked the truck. moved it around till i got an idle and stuck the lever over it. well, i apparently got it one tooth off, cause on order to lower the idle to 700-800 i had to back the idle screw almost all the way out (only about 2 threads sticking out on the lever side). idles fine, runs like a wildcat.
now my question. will having it one tooth off damage anything or allow throttle to stick (over center?). it runs fine. i can take the linkage back of without much problem, but if it aint gonna cause any damage, it'll stay where it is.
thanks in advance
daryl
PS.. i replaced the stock worn throttle bushings (back on the pivot where the cable hooks) with mopar part#4425053 list $1.95 ea. you wouldn't believe the difference in throttle feel. highly recomment this cheap repair for high mileage trucks
CAJUN 93
Postby KTA » Tue Feb 27, 2007 1:07 pm
If you have a really turned up pump and install the spring you will have to back the idle screw down, it wont hurt anything and you probably got the shaft back on correctly. My pump doesnt have any effective idle or high speed screws I have them turned out so far. :twisted:
Postby CAJUN 93 » Tue Feb 27, 2007 1:20 pm
great, that's what i needed to hear. thanks kta. my high speed screw's been just along for the ride for a while too. :lol:
CAJUN 93
Postby PToombs » Tue Feb 27, 2007 5:14 pm
What's a high speed screw? :twisted:
Postby Greenleaf » Tue Feb 27, 2007 5:51 pm
This is a family web site.
:shock:
Greenleaf
tech specialist/mod
Postby TWorline » Tue Feb 27, 2007 7:03 pm
:shock: :oops:
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby PToombs » Wed Feb 28, 2007 3:13 pm
Preverts! :shock: I forgot what that is! :wink:
Postby JLeonard » Thu Mar 01, 2007 10:04 am
Preverts!
Glad you spelled it like I say it!! :lol:
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
Postby jer1 » Sat Mar 03, 2007 8:05 pm
32k, now THAT'S turning some r's. Might be out of the ve's range by then. :mrgreen: LOL
91 W250, 6" susp. lift, 2" body lift, 36" Buckshots, Powersmoke IC, Haisleys studs and fire rings, PDR valve springs, Banks high ram, HTB2 62/14, 4"DP, Dual 5" exhaust, Bullydog boost and pyro (pre-turbo), POD's, tweaked pump, timing bump, 3200 gs
jer1
Postby 92 D/UNIT » Sat Mar 03, 2007 8:24 pm
jer1 wrote:32k, now THAT'S turning some r's. Might be out of the ve's range by then. :mrgreen: LOL
dont think it would be pumping much at 32,000 rpm's :lol:
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby CAJUN 93 » Mon Mar 05, 2007 12:11 pm
well the stg iv sounds like a jet engine on taxiway. my new diesel powered turbine :lol:
the truly funny part is i had it as 3200 and then removed the 0's and added the k :?
thanks for paying attention
daryl
CAJUN 93
