intake
intake
Postby 1991cummins » Wed May 13, 2009 9:04 pm
will too small of an intake cause EGT problems (too hot)? basicly, with my setup i have stock intake due to lack of funds :( and im curious if a bigger one will drop EGT's??? i know i will see higher boost from a higher cfm, but im curious if the loss of restriction pre turbo will help with the temp?
any thoughts appreciated :)
Derek
1991cummins
Postby peobryant » Wed May 13, 2009 9:29 pm
Yep, a bigger intake should help lower EGT's.
Postby 1991cummins » Wed May 13, 2009 9:31 pm
cool, good to hear, cause im fighting egt's right now! :? and water meth didnt do any where near as good as i hoped it would...
thanks
1991cummins
Postby PToombs » Thu May 14, 2009 5:06 pm
If you wanna test it, go for a ride, then pull the inlet tube from the turbo and drive it again. Compare EGT readings, I bet it's a lot different!
Users browsing this forum: No registered users and 78 guests
