DennyT Stage 2 Fuel pin
Postby Bad93Cummins » Fri May 15, 2009 11:53 am
I only have a 4" straight pipe done to my cummins, its a 93 with 347,@@@ miles. Will a DennyT fuel pin be to much for it to tow my mud truck about an hour to muddi gras? I won't have gagues till not this monday but the monday or tuesday after.
Bad93Cummins
Postby peobryant » Fri May 15, 2009 1:08 pm
You would probably be okay, but I would wait and install the DennyT cone until you have gauges, if you're going to be towing.
Postby 2wd_sled_puller » Fri May 15, 2009 1:33 pm
Nope its gonna be to hot sell it to me. :lol:
The HULK 1993 dodge cummins Afc work. Screw turned to runaway. Ht3b turbo looking for sticks
Piper 1997 chevy 2500 vortech 350 soon to be vortech 383
2wd_sled_puller
Postby Bad93Cummins » Fri May 15, 2009 8:43 pm
So think I should wait huh?
Bad93Cummins
Postby soggy » Fri May 15, 2009 9:12 pm
I think you should be fine, as long as you just run that, no pump tweaks?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby peobryant » Fri May 15, 2009 10:03 pm
With no pump tweaks you would probably be okay, but I would still wait to install gauges.
When did you get the DennyT cone?
Postby Crazy Matt » Fri May 15, 2009 11:01 pm
If you drive sanely it should be ok - watch the hills tho
'90 cummins, mod'd 727,converter ,4" from dp back, 16cm,ported exhaust housing/ats manifold, gds 60mm upgrade, 366, dennyt pin, .Ported head, camshaft. In the process of resetting injector pop pressures and put the whole mess back in the truck.
Crazy Matt
Postby Bad93Cummins » Sat May 16, 2009 12:58 pm
there's no hills, im on east side mid florida.
I haven't got the cone yet, was going to try and order it today or monday.
Just haven't been sure weather to install it before or after muddi gras.
Bad93Cummins
Postby Bad93Cummins » Sat May 16, 2009 12:59 pm
and no don't plan on tweaking pump.
Bad93Cummins
Users browsing this forum: No registered users and 81 guests
