cougar wrote:My understanding is the 91s had the 21 and they reduced them back to the 18s because of the delay/smoke problems. In either case, smaller reduces lag time. 16s are good, 14s you need to start worrying about choke down unless you install a waste gate. Weather it will help with EGTs, I really haven't noticed a difference.
Bad93Cummins wrote:Is the one I posted a good buy?
Bad93Cummins wrote:http://www.gillettdiesel.com/16cm2non-wastegatedturbinehousing-1.aspx
The one im looking at getting.
Bad93Cummins wrote:Bad93Cummins wrote:http://www.gillettdiesel.com/16cm2non-wastegatedturbinehousing-1.aspx
This still use the 3" downpipe?
Also could you run this without gagues and nothing but 4" straight pipe done the to truck?
deanhinsley1963 wrote:I,ve Heard that my year c.t.d. will benefit greatly with a 16cm2 housing is this true?? I,m only looking for about 250-300hp and still be able to tow ocasionally?
SOOT4BRAINS wrote:I would say it would be worth it to do. Gauges would not be necessary with just this. I have found with most airflow upgrades (air filter, smaller turbo housing, 4 inch exhaust etc.) it usually lowers temps, but also keeps the temps down longer than before. I had 3 inch downpipe with 4 inch after that. Finally put stans 4 inch downpipe on. Only saw 25 degree difference overall, but the temps stayed cooler much longer while on a hard run. Once the temps are up, they won't come down till you slow down. A 16cm housing will spool faster, getting more air in before it gets hot, and is still plenty of flow on top end so it wont get too hot at higher rpm. The 21 spools so slow, its getting hot without the air, and when it does spool it just does not have the capacity to keep it cool. Smaller housing = more turbine rpm (more boost pressure) and starts spinning sooner. Too small, and its restrictive up top. 16 is great all around housing. I would wait a little and look for a used one though. Good luck
Bad93Cummins wrote:SOOT4BRAINS wrote:I would say it would be worth it to do. Gauges would not be necessary with just this. I have found with most airflow upgrades (air filter, smaller turbo housing, 4 inch exhaust etc.) it usually lowers temps, but also keeps the temps down longer than before. I had 3 inch downpipe with 4 inch after that. Finally put stans 4 inch downpipe on. Only saw 25 degree difference overall, but the temps stayed cooler much longer while on a hard run. Once the temps are up, they won't come down till you slow down. A 16cm housing will spool faster, getting more air in before it gets hot, and is still plenty of flow on top end so it wont get too hot at higher rpm. The 21 spools so slow, its getting hot without the air, and when it does spool it just does not have the capacity to keep it cool. Smaller housing = more turbine rpm (more boost pressure) and starts spinning sooner. Too small, and its restrictive up top. 16 is great all around housing. I would wait a little and look for a used one though. Good luck
would it still be fine with the 3" down pipe, as I just put the 4" on my truck and it has the 3" off turbo then 4" from firewall all the way back and would hate to have to replace.
