The Blue is dead
The Blue is dead
Postby pulltilbroke » Thu May 21, 2009 7:27 pm
Yep its dead its been goin south for a while and it finaly went the other night, I can't complain too much it lasted a year and a half[laugh]
But this it what I replaced it with, its also rated for Alcohol so it should be good with Diesel also
Aeromotive SS series, 140GPH@ 14psi[guitar]
Little bit of size difference between the two also
Postby Richie O » Thu May 21, 2009 8:00 pm
I was thinking of getting a blue for a quick easy way of more fuel. Both of my trucks are in need of a fuel upgrade. I guess I will wait and do it right the first time.
Postby RSWORDS » Fri May 22, 2009 7:07 am
I looked real hard at that Aeromotive pump when doing my upgrade. Didn;t do it because no one had any experience with it. Specs look PERFECT on paper though! Let us know how it works!
RSWORDS
fuel pump
Postby Bigfury » Fri May 22, 2009 9:20 am
I've been useing a mallory 110 with a by-pass regulator. Have more respect for the georotor design over a vane type.Plus with a by-pass regulator it is continastly(sp.) filtering.It's a safty measure running B100.
'90 non I/C,Getrag,4" straight ex.,500,000,wanting bigger- injectors,turbo.In progress is powerjoke I/C,BHAF
Bigfury
Postby pulltilbroke » Fri May 22, 2009 9:37 am
Yeah I've been eyeballin this pump for a while. At idle it pushin 17psi,I havn't really tested it to hard yet, and this is only my street pump, I'm in the process of gathering parts to build a paralell Big system using a "special" 300gph 65psi pump for competition
Postby NYCEGUY01 » Fri Jun 05, 2009 8:08 pm
I ran that pump for a while. Once it got cold outside it leaked everywhere. When I called Aeromotive to buy a rebuild kit the tech guys told me not to bother. He told me that it was designed as a street and strip pump and it would leak everywhere once the aluminum got too cold.
In thier defense they offered me a reman Big pump at no charge or a straight up full refund even though I had had it for over a year.
I took the refund and went back to a Holley Black.
96 chevy 3500 4x4 dually. 1st gen Cummins ,nv4500.
NYCEGUY01
