by SOOT4BRAINS » Tue May 26, 2009 9:32 pm
As far as I know, removing the lever does not affect idle speed. It adds fuel just off idle. Took my buddies afc lever out, and idle was the same. To get the idle down, just re-index the shaft one tooth and adjust with the screw stops from there. I got lots of smoke when I turned my smoke screw in with stock injectors. So much I turned the smoke screw back out because it would smoke even if I was just driving nice.
93 D250 Rag 3.54, 4 inch stans downpipe to custom 4 in exhaust, pump cranked with m3 pin, 366 spring, tach,boost,pyro,fuel pressure, ddp 70lpm sticks, 62/65/12 s300, airdog 150, rebuilt getrag, 3250 SBC clutch, helix 2 camshaft, dual redtops, new paint.
