What will happen if......
Postby dodgetkboy78 » Wed May 27, 2009 11:00 pm
I install 435's before twins. :?
I crapped an injector, and don't want to buy injectors twice, you know, save some dough.
I have a I/C truck, 5 speed, HX35, south bend clutch, cooler tubz.....
Can I just back the screw off, or my foot off until I get another turbo and the twin set up?
dodgetkboy78
Re: What will happen if......
Postby RSWORDS » Thu May 28, 2009 4:20 am
dodgetkboy78 wrote:I install 435's before twins. :?
You got it, back your pump off or try and control your right foot!
RSWORDS
Postby JQmile » Thu May 28, 2009 8:05 pm
With my DDP's I could back em off to where they would barley smoke, even at WOT. With the 6x16's (bigger than 435's) it still smokes like a train even with the screw out two turns. However, EGTs aren't that bad (with the pump backed off) and as long as I stay under 1/2 throttle it barley smokes.
IN other words, you'll be fine.
JQmile
Postby dodgetkboy78 » Sun May 31, 2009 12:08 pm
And what happens if I stomp the sucker?
dodgetkboy78
Postby Richie O » Sun May 31, 2009 1:45 pm
dodgetkboy78 wrote:And what happens if I stomp the sucker?
It will get hot real fast. :D
Postby dodgetkboy78 » Tue Jun 02, 2009 9:56 am
How fast do you guys think?
Think it will top out if fourth before I get too hot? (five speed)
Just wonder how much power the thing will make.
dodgetkboy78
Postby Richie O » Tue Jun 02, 2009 12:04 pm
It all depends on the fuel screw and what fuel pin you have. 435's will get hot in 3rd gear if you have stuff maxed out and no air to go along with it.
When I tow with my 6x16s I need 1 eye on the road and 1 on the egt gauge. I have way more power then I can use.
Users browsing this forum: No registered users and 77 guests
