Pump CC's
Pump CC's
Postby JQmile » Thu May 28, 2009 8:06 pm
Who's had their pump on a test stand? CC's? at what rpm? Mods? 12 or 14mm? etc.
JQmile
Postby seeker1056 » Fri May 29, 2009 4:45 am
first try was approx (bad memory but actual numbers are posted elsewhere on this site) 436cc at 2950 with a 14mm but it died back to around 220 from there on up to 4000 rpm
second attempt with a different setup was about 320cc but held that # pretty close all the way to 4000 rpm and i still have two full turns on the fuel screw left to play with
Giles is workin on a high rpm 12mm (5000) as we speak.
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby JQmile » Fri May 29, 2009 10:56 am
Who's 14mm were you using? KTA's or Rocken Tech's?
JQmile
Postby sdubfid » Fri May 29, 2009 3:24 pm
Can't wait to see the results of giles 12mm pump. When will it be ready? Whose truck is it for? Or just an experiment?
93 w250, a518, holset he351, ddp 75hp inj, 4" turboback, denny t stg 2, piston pump, pdr pump, 3rd gen seats, ps intercooler
sdubfid
Postby fergavs » Fri May 29, 2009 6:26 pm
I don't remember exact numbers (can be found on another post) but my current non intercooled pump did over 400cc at 1600 stand rpm (3200 engine rpm) with the 14mm/4mm combo and 6-18's. Currently it makes well over 300cc of fuel at the same rpm and same injectors with the 14mm only.
I know I am making that kind of fuel because even with a 64mm turbo running 55psi, ported head, and cam I still couldnt control the egt's.
fergavs
Postby JQmile » Sat May 30, 2009 7:07 pm
Nice, what happened to the 14/4mm? Sieze?
JQmile
Postby seeker1056 » Sat May 30, 2009 7:40 pm
no - broke the ears off of the cam plate, but I suspect the clover leaf shaped part broke first - I am thinkin maybe too much torque from the fuel load caused the failure - its a very tiny cross section
anyway, no a piece of shrapnel got into the head
usin rocken techs 14mm
the high rpm 12mm is an experiment I asked Giles to pursue for truck pulling and if it works will eb on my truck next season or sooner
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby fergavs » Sun May 31, 2009 10:08 am
That was the exact same failure as mine. Broke the ears off the cam plate. I also suspect it was fuel load but I believe it was from fuel backing up in the pump because the pump tech attempted to use his test injectors. (way to small a tip)
fergavs
Postby JQmile » Mon Jun 01, 2009 4:52 pm
Just got word...440cc :D
14/4mm. Never felt so much like using that smiley.
JQmile
Postby dvst8r » Mon Jun 01, 2009 5:52 pm
JQmile wrote:Just got word...440cc :D
You sir are now OVER FUELED! 8) Forget the small shot of Nitrous forget the medium shot, heck for get the pill all together, you will need an open line to burn all of that. :shock:
1990 W250 non ic'd. Under the knife again.
dvst8r
Postby fatty » Mon Jun 01, 2009 6:17 pm
What RPM? By the way that's pretty good for the VE no matter what RPM
Postby JQmile » Mon Jun 01, 2009 7:03 pm
Haven't got all the details yet, I'm sure it's down at like 2800 or something. Don't have the pump yet. And as for being overfueled, I was thinking yes, air, and lots of it. At least two stages of nitrous and another turbo 8)
JQmile
Postby slowdiesel » Tue Jun 02, 2009 10:46 pm
Who's Pump? and what size injector's was this flow through?
1984 D100 Ve-Twins.
Special Thanks Mayer Farm Equipment
slowdiesel
Postby slowdiesel » Fri Jun 05, 2009 5:35 am
tt
1984 D100 Ve-Twins.
slowdiesel
