Another turbo question
Postby cougar » Sat May 30, 2009 8:29 am
After reading other posts and signatures, The HX35's and HX40's will bolt up to an H1C's turban housing.
True? False?
Any other compressors out their will bolt up?
What do I need to adapt the "flange" on these turbos to the straight tube on the H1C?
01 2500 "the work truck".
cougar
Postby swank » Sat May 30, 2009 9:20 am
35's will slide in there. 40 has a different size turbine.
Adapt? Yours is non-IC? I've never dealt with this. I'm sure somebody will pipe in on that.
Dave
truck
swank
Postby cougar » Sat May 30, 2009 9:34 am
It is intercooled. The H1C's have a straight tube coming off the compressor outlet were as those after have a flange.
I am hoping to get a little more air in without major changes to the down pipe. Unless there is a simple conversion available.
I'm trying to keep the $$$$ down.
cougar
Postby swank » Sat May 30, 2009 3:34 pm
If it's intercooled, there should be a flange that a 90* elbow is clamped to. The 35 has this same flange. At least my h1c has a flange.
truck
swank
Postby Richie O » Sat May 30, 2009 4:03 pm
The 89,90, and early 91 ( non i/c ) has the straight rolled bead boot connection that you talk about. Every 91.5 up I have seen has the flange with a v band clamp.
Postby cougar » Sun May 31, 2009 9:23 am
How are people adapting the larger flange turbos to the 89-93 trucks? 94 and after have a different angle on the down pipe and also most have wastegates that move the exit even further aft.
Oh! Who is GDS and HTT that has these 60mm wheels? Never mind, found them.
cougar
Postby Richie O » Sun May 31, 2009 1:51 pm
You can get a 60 mm GDS kit for the non ic style. You then need to adapt the outlet size to the stock cross over or build your own bigger cross over intake.
Users browsing this forum: No registered users and 82 guests
