3200 rpm spring
3200 rpm spring
Postby Firstgen1 » Mon Jun 01, 2009 6:53 pm
does it give you a power gain the hole way through the power band or just on top, how much more boost do you get
thanks
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby burnt_servo » Mon Jun 01, 2009 7:24 pm
it allows the engine to pull more rpm , nothing more , before the govenor starts to defuel the engine .
'93 w250 .... stock ...
burnt_servo
Users browsing this forum: No registered users and 83 guests
