top speed
top speed
Postby hassy21 » Fri Jun 05, 2009 11:42 am
my truck before the lift and 36's hit 100 mph somewhat easy, now i can hit 80-85 mph no matter how long im in the throttle. I also since then bumped the timing, its about a half inch from the head.
hassy21
Postby RSWORDS » Fri Jun 05, 2009 1:05 pm
I bet your tire size is throwing off your speedometer that much
RSWORDS
Postby Begle1 » Fri Jun 05, 2009 1:50 pm
Ya mon... At the same RPM you're gonna be moving fasta now.
