I finally got the Fummins all the way together, leagal, and on the road over the weekend. The maiden voyage was a 600 mile trip from my dad's shop in Missouri to my apartment in Oklahoma. The truck runs like a champ, even drives pretty good considering it's size and makeup. However, the EGT's were between 1000 and 1150 degrees the whole way, even letting waaaaaay off the throttle going up hills to stay away from 1200. Granted, I'm pulling 38 inch rubber and the truck is no lightweight, but I'm a little concerned.
The innards are stock. No intercooler. HTT Pulse 3-piece exhaust. HTT Stage IV 60mm compressor. 16cm2 exhaust housing. Pump turned up half turn from runaway. DDP fuel pin. Stock smoke screw. Star wheel turned down. Unknown injectors (past owner said they were 40hp+ injectors, but I'm assuming he got swindled and they are stock because the fuel screw was tampered with on the rebuilt pump that he said he never touched). Also, open element K&N air filter. Stock downpipe to 4 inch straight exhaust to dual 4 inch stacks. 4.10 gears 10 inch lift and 38 inch tires.
Logical answer is add an intercooler, but I don't have the resources readily available to add an intercooler any time soon. Are there any cheap and easy ways to lower the temps without losing too much power? Is there anything drastically wrong with my setup that I'm overlooking?
Like I said, stupid question, but I'm on a budget and lacking the tools to get any serious fabrication done. Feel free to bash me all you want. I just don't want to melt the poor thing down, but I still wanna go fast. Heck of a perdicament...
