Drive Pressure
Drive Pressure
Postby 93_Fummins » Fri Jun 26, 2009 10:05 am
To those who are keeping an eye on it, what kind of setup are you using to monitor drive pressure? Are there gauge kits, or did you fab something?
I know there was an article in DieselPower on a drive pressure gauge setup, but I totally breezed past it because I wasn't concerned with drive pressure at the time. Now I'm curious about it, but I can't find the issue.
Any suggestions would be greatly appreciated. :grin:
93_Fummins
Postby Begle1 » Fri Jun 26, 2009 1:02 pm
The most common set-up involves a few feet of copper tubing ran from the manifold to a pressure gauge.
Creative folks use electronic pressure transducers instead of gauges and put a filter in line.
Postby JQmile » Fri Jun 26, 2009 2:42 pm
If you want to be cheap about it, you can use a copper tube hooked up to an oil pressure gauge, and plug it in to where your pyro used to be. Set it on your hood and make a pass down the street :D As long as you don't change anything, there you are-you know your drive pressure.
JQmile
Postby Begle1 » Fri Jun 26, 2009 2:45 pm
Hook it to a tire pressure gauge. Not only is that cheaper than an oil pressure gauge, it stores the highest pressure reading!
Postby JQmile » Fri Jun 26, 2009 3:02 pm
LOL NOW we're talking 1st Gen stuff!!
JQmile
Postby seeker1056 » Fri Jun 26, 2009 3:43 pm
I am using a liquid filled 100 psi gauge I bought from princess auto for $20 and copper line. Reads excellent and no issues with carbon so far
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Begle1 » Fri Jun 26, 2009 3:54 pm
seeker1056 wrote:I am using a liquid filled 100 psi gauge I bought from princess auto for $20 and copper line. Reads excellent and no issues with carbon so far
Is it backlit?
Postby gear jammer 91" » Fri Jun 26, 2009 5:13 pm
Begle1 wrote:Hook it to a tire pressure gauge. Not only is that cheaper than an oil pressure gauge, it stores the highest pressure reading!
Just make sure to use duct tape that is color coordinated to your truck when you tape it to the windshield wiper. :lol:
01 LB7
gear jammer 91"
Postby randyswelding » Fri Jun 26, 2009 9:46 pm
where are yall hookin it in at :? that has me stumped and how much is too much dp
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby JQmile » Fri Jun 26, 2009 10:46 pm
randyswelding wrote:where are yall hookin it in at :? that has me stumped and how much is too much dp
Ideally you want about a 1:1 drive to boost ratio. Anything more than 1.5:1 drive to boost is usually pretty bad. So if you're running 50psi, you should have about 50-75psi of drive. Less is always better. Some diesel racing engines that operate in narrow RPM ranges will actually be on the negative side. Somewhere around 70psi drive 90psi boost.
JQmile
Postby 93_Fummins » Sun Jun 28, 2009 7:13 pm
Fair enough. I just didn't know if there was any trouble with heat and soot and mechanical gauges. I'm not quite to the turbo tuning point yet, but I'm trying to get all my ducks in a row before I get too carried away.
93_Fummins
Postby 93_Fummins » Thu Jul 02, 2009 8:52 am
Never mind. The article I was thinking about was in Diesel World, not Diesel Power, and was for the new ISSPRO Performax electronic gauge system. :oops:
It's a pretty trick system too. It uses a computer to take signals from various sensors and sends output signals through 3 wires to be picked up by as many guages as you want. The gauges are daisy-chained together and only pick up the signal intended for them. Each has stepper motor needle movements and an auto recall feature.
93_Fummins
Postby Richie O » Thu Jul 02, 2009 9:13 am
93_Fummins wrote:Never mind. The article I was thinking about was in Diesel World, not Diesel Power, and was for the new ISSPRO Performax electronic gauge system. :oops:
Ya. Don W. from isspro was talking about thoes to me last time I had him on the phone. It sure would be easier to hook up but I bet they are pricey.
