Ok, got a replacement WH1C on her...had to use the old snail on the exhaust as mine is v-clamped. I have noticed a bit more smoke on take-off and now I have boost throughout the rpm range with it showing max at 29lbs @ 2850rpm 1295exh.
did a standing start run and did 0-100@ 10.5sec 1st run with eng temp at 198deg and 2795rpm
2nd run 210deg 0-100@ 9.8 sec 2890rpm
Launches were made at 1900 rpm...any higher and the boost is over 25lbs and just smokes the tires.
no 1/4 markers nor dyno yet....how can I figure what she would do in the 1/4 mile?
Are these numbers any good?
