is it worth it
is it worth it
Postby Firstgen1 » Wed Jul 08, 2009 6:13 am
for evryone who has swaped a getrag or helped swap a getrag into an auto, is it worth it or should i just beef up the auto. how hard is it and what problems did you run into.
this is if i can even find a getrag :lol:
thanks
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby Richie O » Wed Jul 08, 2009 6:10 pm
Bradshaw106 just did his last month. Maybe pm him and see if he replies. He is not on much.
Postby dpuckett » Thu Jul 09, 2009 11:06 am
rbrettctd and Tippin Spotted Cow also have done auto to 5spd conversions. At least I built a Getrag tranny for TSC a year ago...... Rbrett gained several MPG by ditching his auto- to the tune of 3-5, IIRC.
Daniel
Postby bgilbert » Thu Jul 09, 2009 12:50 pm
Oldcool90 did the swap into his 3.08 727 truck. I'm sure he'd never look back or regret it. IMO it's the best upgrade, and the only one for that matter, for the nonlock-up auto. Matt might jump in and tell the HP gain from auto to stick. IIRC it was good for 60hp to the ground on the dyno, auto to getrag.
Bill Gilbert
bgilbert
