Well, I fired it up, no obvious leaks.
I have to hit the primer bulb about 200 times to get the filter filled up. That's pretty awesome.
I didn't find a very good mounting location for the filter. I had to mount it between the frame and the bellhousing on the driver's side. It's nice and cozy there and doesn't get in the way of anything, but it's the very bottom part of the system. So filter changes are going to suck. I might need to work in a couple ball valves.
The little water separator bowl on the bottom is just asking to hit something too. Especially the stupid little drain nut that you thread UP to open, so it sticks about an inch farther down than anything else on the bottom of the truck. If I keep it there I might need to carry a replacement for the inevitable road hazard.
Um, the little clear water separator bowl on the bottom is supposed to be full of fuel at all times? I wasn't expecting that.
