This is my first post here and I got an question regarding injection pumps.
So, I want around 450-500hp out of my first gen Cummins and I am undicided if I should use an VE pump with an 14mm pump head or an P pump ! Is the VE up the task ? Or should I switch to the P pump (185hp version).
I also got an 5.9L 12V build in 99 with an VE pump (european truck engine) and this engine uses the 24V block (53 casting) and the head like they used on the 98 12V with the inline pump. Are the internal parts of the newer engine better (pistons etc) and is the head better ??
Daniel
