Fluids
Fluids
Postby slingshot » Sun Aug 16, 2009 6:15 am
What are some of you running for fluids in your trucks, as far as motor oil, automatic trans fluid, manual trans, transfer case, differentials?
1993 W250 5speed.
slingshot
Postby Richie O » Sun Aug 16, 2009 6:30 am
We buy Rotella by the 55 gallon drum for all our diesels. The rest is usually store brand fluids.
Postby slingshot » Sun Aug 16, 2009 7:33 am
I run these:
Engine-Rotella/ lucas
Getrag-Mystic 15w-50/ lucas
NP-205-Mystic 15w-50/ lucas
front and rear differentials-SAE90 lucas
1993 W250 5speed.
slingshot
Postby dpuckett » Sun Aug 16, 2009 12:32 pm
I run store brand stuff in everything, unless I find a closeout on the big name stuff.
Engine- 5000mi- 15w40 of some sort. Prefer CI4 rated vs the new CJ4 rated, which means farm store brand now days.
Getrag- 15-20K mi- same as the engine, except no prejudice toward API rating.
A518- 15K/ yearly- AT+4. Might be slight overkill, but beats me having to R&R the auto tranny (I will never do another one again).
T-case- 25K mi/ yearly- 80w90 gear oil.
Rear diff- same, with 2 bottle of Mopar friction modifier if I have a limited slip. I've had the results of not enough FM, and will take a little one wheel peel vs rebuilding the rear diff.
Gear boxes get synthetic if I dont have any leak issues. Figure the engine will go a million miles with cheap oil and filters, I'll put my money in protecting the drivetrain behind it.
Radiator- Wal Mart brand antifreeze mixed with distilled water. DO NOT add any coolant additives for cavitation erosion- our engines do not need it, and the silicates will just gunk stuff up. Change every other year or 30K.
Brake fluid- Store brand, flush every 2 years, mileage irrelevant.
PS fluid- same as brake fluid. NO ATF!!
Postby PToombs » Sun Aug 16, 2009 5:00 pm
Mobil brand 15-40 in the engine, same in the Getrag. (what we have at work ;) ) Change the oil every 2 years or so, I only put about 5k on it in that time. Maybe more this year, as I have been actually driving it and not overhauling so much. 8)
Diff, 85-140, also Mobil.
Brake fluid when it blows a line.
Steering, ATF. :lol:
DP, why no ATF in the steering?
Postby Crossy's son » Sun Aug 16, 2009 9:49 pm
Universal tractor fluid (15-40) in the engines and Genuine Mopar filters on all cummins around here
Auto trannies get ATF+4 because don't want to take the chance with Dexron Mercon.
Coolant is recylced coolant from the local auto wreckers, filtered.
power steering fluid is whatever, i think dollar general brand or something.
brake fluid is STP
rears get 80-90
91.5 W250 5 speed, 500k miles, 3.54's, Powr-Lok, 4" Str8 Exhaust , Egt/Boost on pillar, 435 Injectors, Borgeson Steering shaft, HX35/12wg, 4" lift on 35's, dyno 5/18/13 302hp/792 tq
90 D250 727 3.07's 227k miles
Crossy's son
Postby dpuckett » Mon Aug 17, 2009 2:56 pm
Pete- I read somewhere that it wasnt good for the pumps. My personal experience with ATF and P/S pumps backs that up- they either leak or just flat quit after a little while. Could be coincidence, but about 3 of my 1stGens have gotten new P/S pumps through the years. After the last one, I started using Wally World Super Tech P/S fluid, and have done ok so far.
DP
Postby PToombs » Mon Aug 17, 2009 3:49 pm
OK, thanks. It's all I've ever run, so I wondered.
