Who is runnin glowshift gauges?
Postby Oddfire » Thu Aug 20, 2009 4:39 am
Picked up a used set of gloshift pyro and boost gauges today and I cant get the boost gauge to behave. There are 4 wires coming out the back and I was wondering if (since they didn't come with instructions) anyone remembers how they go....
I figured it was a normal pressure gauge and that is you just plumb the line, if you give it pressure, it should read. I gave it about 35lbs and no go. :?
Oddfire
Postby BAC » Thu Aug 20, 2009 8:18 am
the black wire is ground the other three are 12v some of the 12volt are supposed to be switched and some are constant so it keeps memory so it will stay on the color of your choice but i dont rember which is which i just put them all on 12volt when the key is on.
BAC
Postby PToombs » Thu Aug 20, 2009 6:23 pm
I have some in my funny round truck. I know the numbers are kinda small and the color they are sucks! I didn't know you could change them. I'll have to check into that.
Oh, and the boost works, but the pyro seems to be a union helper. :roll:
