how much horsepower
how much horsepower
Postby james-93-12valve » Fri Aug 28, 2009 12:55 pm
i was just wondering roughly how much horspower i have my pump is turned up as much as it can go everything else is stock
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby 93_Fummins » Fri Aug 28, 2009 1:14 pm
Give a rundown of all the mods, if any...
Injectors?
Intercooler?
Downpipe?
Intake/airfilter?
Boost tubes/intake horn?
Fuel Pin?
Govenor Spring?
Smoke Screw/Starwheel Mods?
Timing?
Turbo Setup?
Boost and EGT numbers at given loads and speeds?
Without running it on a dyno to find out, it's just going to be a guess...
93_Fummins
Re: how much horsepower
Postby Oddfire » Fri Aug 28, 2009 1:25 pm
james-93-12valve wrote:".... everything else is stock"
Oddfire
Postby 93_Fummins » Fri Aug 28, 2009 2:21 pm
Hmmm, I must have been hanging over a little worse than I thought this morning...
93_Fummins
Postby MMeier » Fri Aug 28, 2009 4:57 pm
He says stock, yet shows 4" exhaust in his sig... so what else is changed, air intake? etc.? If thats about it, I'd say you have maybe 160 at the wheels. Put the thing on a dyno!!
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
how much horsepower
Postby bulltamer » Fri Aug 28, 2009 5:28 pm
he got a stock exhaust straight piped with a 5 inch tip
star wheel turned in deep as it can go, smoke screw turned all the way in
fuel screw in lik two turns with a BHAF
no gauges
stock '92 d350, auto, extended cab, 9 LEDs on each side, straight piped
coming soon: clear tail lights, fender lights, tailgate lights and clear second gen. cab lights
bulltamer
Postby james-93-12valve » Fri Aug 28, 2009 10:36 pm
bulltamer wrote:he got a stock exhaust straight piped with a 5 inch tip
no gauges
actually my fuels screw is all the way in
james-93-12valve
Postby 93_Fummins » Tue Sep 01, 2009 6:09 am
bulltamer wrote:
no gauges
:shock: :shock: :shock:
93_Fummins
Postby meby » Tue Sep 01, 2009 6:51 am
[quote="james-93-12valve"
actually my fuels screw is all the way in[/quote]
Hp can vary quite a bit from on truck to another given how worn certain parts are such as injectors.
That said, my last truck had the fuel screw turned all the way in (past the collar), had several other minor pump modifications (afc related and 366 spring), 21 cm exhaust housing, and had a 4" straight exhaust. It would do 85 in a quarter at its peak (7700 lb I/C'd truck). Punch that into a hp calculator and it was running in the vicinity of 370 hp at the crank (according to several web calculators).
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby JQmile » Thu Sep 03, 2009 10:33 pm
I'd guess 220-250 at the wheels. Run it down the quarter mile if you're too cheap to dyno it. :D
They have HP calculators that can get pretty close.
JQmile
