stock turbo
stock turbo
Postby james-93-12valve » Thu Sep 17, 2009 8:39 pm
what is the stock turbo on a 93 d350 5 spd also what is the bigest downpipe i can put on it and would a 4inch exhaust from turbo back make a diffrence
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby TTipswprd » Thu Sep 17, 2009 9:34 pm
h1c is stock. i personally dont see how a 4 inch dp makes a difference when your turbo outlet is 3. i think just going 4 inch from dp back is plenty good.
TTipswprd
Postby peobryant » Thu Sep 17, 2009 10:28 pm
Like said, your stock turbo is an H1C with an 18.5cm housing.
A 4" exhaust system is a good upgrade, but with a turbo like the H1C that has a 3" exhaust outlet, a 4" downpipe won't do you any good until you step up to a turbo with a 4" outlet.
That's what I think anyways, but I've been wrong before. :D
Postby MMeier » Fri Sep 18, 2009 12:16 am
Put a Super B turbo on mine, really like it !! 4" all the way through also !! 8)
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby peobryant » Fri Sep 18, 2009 1:12 am
MMeier wrote:Put a Super B turbo on mine, really like it !! 4" all the way through also !! 8)
I always get confused with those names. What is the Super B? Is it the S300G or a larger one?
Postby Richie O » Fri Sep 18, 2009 10:01 am
I believe the super B is the 57mm model. The other custom sizes ( 62, 64,66, ) is the super b special. So I have been told, but who knows. :D
Postby james-93-12valve » Fri Sep 18, 2009 11:32 am
so would a 4 inch from dp back make it louder
james-93-12valve
Postby fergavs » Fri Sep 18, 2009 2:43 pm
Loudness typically has to do with the muffler, the diameter of the pipe usually just makes the sound deeper. As far as turbos the Super B is a s300g with an extended tip upgraded wheel. The Super B Special only comes in one size the 64/71/14. It also has the extended tip wheel. Upgrading to a 4" downpipe could help slightly in that the exaust will expand as it enters the larger diameter of the 4" downpipe which will help pull some exaust out. Now turbo vehicals typically have a fair amount of positive pressure pushing the exaust out already so the expansion of the gases may not help as much as non turbo applications. .02$
fergavs
