truck has a dead cylinder
Postby boostedve » Sun Oct 04, 2009 11:10 am
went to the track yesterday drove the truck there did my burnout staged and then about 1/8 mile the turbo let go a loud pop and white smoke.. i get out and see that it broke the turbo in 2 i get it home pull the turbo off the intercooler out and fire it up number three cylinder is wet with fuel and is missing.. so i pull the injector out check it out and put a different injector in stil lthe same thing.. all the fluids look fin and the truck has no blow by.. what could it be..
FOR SALE 1991 dodge d350 hx40 2nd gen intercooler, few pump mods, 366 spring, no afc, timing bump,pistion lift pump, 5" down pipe, bhaf, old smokey fuel pin, boost, pyro, tach gauges 14.10 @96mph 310hp, pm for pics and info..
boostedve
Postby SNOOT » Sun Oct 04, 2009 11:20 am
Broken valve spring, bent pushrod, or part of the turbo stuck in valve?
Broken valve is my guess..
Pull the valve cover off and have a look see.
1993 W350
SNOOT
Postby boostedve » Sun Oct 04, 2009 11:31 am
everything looks good unless it bent the vavle
boostedve
