Piston lift pump conversion help
Postby cumminsram » Sun Oct 11, 2009 7:17 pm
Long story short I finally found and bought another 1st gen. A 93 reg cab 4x4 auto with a pump conversion nearly finished but it still has the old style rotary ip lift pump. Does the piston lift pump function corractely on ic ed cam? But he thinks they changed to a newer cam but wasnt sure so I thought id ask if it does function properely on :lol: a 93 cam.
Thanks guys and it feels good to be back.
03 duramax reg cab 4x4 6sp blue, daily driver
93 w350 reg cab 4x4 5sp single wheel
sold: 1993 auto 4x4
SOLD:1990 power ram 250 4x4 5sp
cumminsram
Postby crewcabxlt » Sun Oct 11, 2009 7:26 pm
yes should work fine,
crewcabxlt
Postby ahale2772 » Mon Oct 12, 2009 5:50 pm
the cams are all in the same position i just finished my piston pump set up this week dont be fooled by the angle of the rod that contacts the lobe it looks low but works fine i did the 30 psi pump with a mallory regulator it looks an works mint
Postby IowaCummins » Tue Oct 13, 2009 10:04 pm
besure you have the spacer that is required for the riston pump. i think its like a 1/4" thinkc then two gaskets and remove the block insulation a bit and your good to go!
IowaCummins
Users browsing this forum: No registered users and 65 guests
