3k+ rpm vibration
3k+ rpm vibration
Postby apwatson50 » Fri Nov 06, 2009 3:00 pm
I've got a pretty good vibration when I run the rpm's up to and over 3k. Doesn't matter in what gear, even at idle. I tried running without the fan, vibration is still there, at idle I disengaged the clutch and ran the rpm's up and the vibration is still there.
One thing is that the more load that is on the engine, the vibration seems to start at a lower rpm.
Any ideas? I'm thinking maybe an injector? I'm going to get a heat gun and see if all cylinders are the same temp.
Thanks, Aaron
92 Cummins, 4x4, 270K miles
apwatson50
Postby mprmn08 » Fri Nov 06, 2009 4:41 pm
check your balancer. make sure its not comin apart on you. im not sure if a cummins balancer is like many factory gasser balancers and has the rubber ring inbetween a two piece balancer or not but just a thought.
chris
mprmn08
Postby SOOT4BRAINS » Fri Nov 06, 2009 5:34 pm
I just ordered a fluid dampr because of the vibrations in mine. I thought it was from my dual disc hub, it has super hard springs in it. But it has gotten worse and I can see the balancer is not turning true, its off just a little bit. I would check it out. Look at your tensioner, if its moving a lot, a pulley is not straight. That's how I found mine.
93 D250 Rag 3.54, 4 inch stans downpipe to custom 4 in exhaust, pump cranked with m3 pin, 366 spring, tach,boost,pyro,fuel pressure, ddp 70lpm sticks, 62/65/12 s300, airdog 150, rebuilt getrag, 3250 SBC clutch, helix 2 camshaft, dual redtops, new paint.
SOOT4BRAINS
Postby apwatson50 » Mon Nov 09, 2009 8:52 am
It could be the balancer, I'll check, but it is pretty new, probably less than 10k miles.
I think the one other thing I might do is take the belt off completely and rev it up, to completely eliminate all accessories.
apwatson50
Postby SNOOT » Mon Nov 09, 2009 1:02 pm
SOOT4BRAINS wrote:I just ordered a fluid dampr because of the vibrations in mine. .
If you got a fluid dampr make sure you check your fan clearance. They make a fan spacer to move your fan about 1/2" out away from the dampr so they do not hit each other.
They did not know about it a couple years ago but they do now and I have one on my truck. I just hope they included one for you when it comes or made some kinda change.
1993 W350
SNOOT
Postby SOOT4BRAINS » Mon Nov 09, 2009 1:16 pm
Yeah SNOOT, I heard about that right after I ordered it. They ordered me the 92-98 kit with the sensor relocator, not sure about a fan specer though. I am going to have to get a new fan as mine is still bent from the wreck. I might try to straighten it out, but not sure its worth messing with. I'll have to make a spacer for it when I get my new fan and fluid dampr on I guess.
SOOT4BRAINS
Postby burnt_servo » Mon Nov 09, 2009 2:22 pm
the sensor that is being relocated , where is it's normal place ?
i'm still sorting a ton of stuff out on my truck , which was hit really hard on the front end . ( meaning a alot of stuff had the stuffing smashed out of it )
'93 w250 .... stock ...
burnt_servo
Users browsing this forum: No registered users and 66 guests
