New idea for piston pump upgrade!
Postby darestie » Sun Nov 08, 2009 10:05 am
So I really want to convert to a piston pump before I install a 366 spring. I'm a little sore about spending the $190, i'd much rather find a way to make the $90 2nd gen pump work without spending a fortune on a regulator. I ran across this write-up on making a homebuilt regulator for around $20. It would require a bit of experimenting in order to get a spring/shim pair that would hold a target 15psi, but it's a pretty simple concept. I will run the return line back into a T in front of the LP. PLease share your opinions/suggestions.
Here is the write up link
http://www.cumminsforum.com/forum/general-tech-articles/17179-homebrew-fuel-regulator-bypass-valves.html
1993 D250, 5speed. starwheel turned, ASA Intake, M&H M3 fuel pin
darestie
Postby Ace » Sun Nov 08, 2009 10:10 am
I wouldn't risk the front seal on the VE for something like that. You are going to have $25-30 in it after you buy all the brass anyway. Just get a real regulator.
Ace
Postby RSWORDS » Sun Nov 08, 2009 12:47 pm
I run a mallory regulator that was $99... Works VERY well.
RSWORDS
Postby burnt_servo » Sun Nov 08, 2009 1:22 pm
they have a steel ball bearing as a check valve ,mated against a brass fitting for it's sealing surface .
my concern would be the bearing pounding out the brass sealing surface .
maybe replace the brass piece with a piece of stainless , then use some lapping compound to lap in the bearings profile into the new stainless sealing surface .
with that said , what is your time worth ?
what do you do if it fails on the side of the road ?
'93 w250 .... stock ...
burnt_servo
Mallory
Postby ZSkibo » Sun Nov 08, 2009 3:37 pm
I 2nd the Mallory. No problems thus far and I get boost referenced fuel pressure.
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
Postby PToombs » Sun Nov 08, 2009 5:38 pm
Don Tank on here said to remove one of the springs and it would lower the pressure. I've never done it, so I can't say for sure, but it might be something to look into.
Postby dragrdan » Sun Nov 08, 2009 6:49 pm
Actually what Don said was to switch the spring from the low psi pump(or one of equivalent pressure) into the hi psi pump.
93 W250 5spd, Comp 275, HE351CW, 5X18, IP turned up, 3200 spring, BHAF.
dragrdan
Postby darestie » Sun Nov 08, 2009 10:26 pm
Those Mallory regulators are designed for gas, would running diesel be a problem?
Can you buy just the low pressure spring from cummins? Then I could just swap it out.
I may just do the Mallory regulator, can someone post a picture of how they ran the lines and what fittings they needed? Thanks.
darestie
Postby dragrdan » Mon Nov 09, 2009 8:16 am
I don't believe you can get just the spring, but if someone has a low psi pump sitting around, maybe they can pull the spring, measure it, and get the spring rate?
I do know that the 2nd gen lift pump is a higher volume pump than the low psi pump, so that using it(either with a regulator, or spring change) has that as an added benefit.
dragrdan
Postby ahale2772 » Mon Nov 09, 2009 8:21 am
I 3rd the mallory , it works great and is cheep zskbro has a post called "my new fuel system"
Postby dpuckett » Tue Nov 10, 2009 10:36 am
Ok, If you buy a $90 lift pump, then put on a $100 Mallory regulator, arent you back up to the $190 that the original poster is trying to avoid?
I think you can buy the springs independently to switch from a high pressure to low pressure. I'll ask Don if I think of it.
DP
Postby dragrdan » Tue Nov 10, 2009 10:58 am
dpuckett wrote:Ok, If you buy a $90 lift pump, then put on a $100 Mallory regulator, arent you back up to the $190 that the original poster is trying to avoid?
DP
Yes, plus extras(plumbing to adapt it in), but you do get the added benefit of a higher volume pump.
Ideal low cost would be the 2nd gen pump with a low psi spring tho.
dragrdan
Postby ahale2772 » Tue Nov 10, 2009 2:23 pm
I think the low psi spring might make the pump lazy though, being that its a higher volume could be wrong...all I know is that alot of guys that have the 15 psi pump say they can still bring them down to 5 or less psi at WOT...I'm having trouble keeping my pressure to a minimum of 15 at WOT ...thats worrth the extra money in my mind...do it right once id say
Postby Ace » Tue Nov 10, 2009 2:53 pm
ahale2772 wrote:...all I know is that alot of guys that have the 15 psi pump say they can still bring them down to 5 or less psi at WOT
That problem is the plumbing, not the pump. Show me one who upgraded or replaced the in-tank pickup. You can install as big of lines as you want, 1/2", 3/4" ten inch, it don't amount to a hill o' beans if it's still sucking through the 9/32" pickup inlet hole.
Ace
Postby dragrdan » Tue Nov 10, 2009 4:53 pm
I agree 100% with Ace. If you havent done something with the pickup in the tank, every other fuel system mod is for nothing. You can only flow as much as the littlest flowing part of the system, and that is it.
dragrdan
Users browsing this forum: No registered users and 65 guests
