by Crossy's son » Tue Nov 10, 2009 5:36 am
Well i had the old "bad" 93 pump up on the bench with "boostedve" and removed the throttle linkage assembly and found that the throttle shaft spun effortlessly 360* ... immediately i thought "the gov. spring broke".
Found this-
what we found was the area where the pin rides was SO warn out and thin that it wasn't doing its job anymore..theres no doubt in my mind that little peice of metal is as thing OR THINNER than an aluminum mountain dew can....
thought i'd share. LOOK AT THIS WHEN YOU HAVE YOUR PUMP TOP OFF!!!
I guess that makes sense, the PO said he was driving it and it just shut off and wouldn't restart.
Brandon
91.5 W250 5 speed, 500k miles, 3.54's, Powr-Lok, 4" Str8 Exhaust , Egt/Boost on pillar, 435 Injectors, Borgeson Steering shaft, HX35/12wg, 4" lift on 35's, dyno 5/18/13 302hp/792 tq
90 D250 727 3.07's 227k miles
