KTA wrote:Be shure you dont push the pump key out when you are putting the gear on thats my advice.
Fnschlaud4620 wrote:Why is this needed?
Is there not enough advance avaliable with just moving the pump in the oblonged holes?
sorry about all the dumb newbie questions
Fnschlaud4620
Rebel Ram wrote:I was being patient to see why this would be done. In my adventures in pump play, I have had my pumps turned in the advanced direction enough to make my engine miss and shake under moderate acceleration. Is the desire to advance a tooth due to the need for more room between the AFC housing and the head? So do tell. BTW I time by ear and performance. Small adjustments till I get that sweet spot. Please dont tell me this is dangerous. Its always worked for me. As soon as I find out its wrong I'll have problems.
bgilbert wrote:If you got the cover off, I suggest rotating the engine to TDC, which will line up the marks on the cam gear and pump gear. The pump gear letter will be E. Rotate it to C. If you try like I did the first time by just pulling the gear anywhere, not placing the engine at TDC, like I do when I pull pumps (keyway at 1 o-clock), the damn pump shaft might be in between cylinders and click/jump/move on ya . Then you gotta mess with everything to get back to where you started. It's much simpler by doing the TDC thing, which the key will be at 6 o-clock, just keep an eye on it, and then pull the gear, back the engine up a tooth, put the gear back on. Clear as mud?
