When is a BOV needed?
Postby Fnschlaud4620 » Fri Apr 20, 2007 8:52 am
I was wondering if a blow off valve is needed with compounded turbos?
I have heard that you can snap the shaft on turbos when you let off the gas pedel too fast, I also know that without a throttle plate you can't use a normal vac operated BOV? or is there a way to do this? I heard that you have to use switches on the throttle?
Can someone fill me in.
Thanks
Fnschlaud4620
Fnschlaud4620
Postby 90firstgen » Fri Apr 20, 2007 11:30 am
I would like to know some options for this too. I realize our MWE slots mostly take care of the probem but a BOV would be nice
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby Fnschlaud4620 » Fri Apr 20, 2007 2:23 pm
I dont have MWE slots in my H1E, Think this is a problem?
If I have to, I suppose that I will have to put it on the lathe and make some.
Fnschlaud4620
