motor swap
motor swap
Postby ahale2772 » Thu Nov 19, 2009 2:46 pm
ok so this winter/spring my truck is getting a p pumped 12 valve from a bus, im trying to figureout weather or not i can use a stock style bellhousing, im going to throw a getrag behind it, i just dont know if the bus block will accept a getrag...any input?
Postby PToombs » Thu Nov 19, 2009 6:13 pm
The block should drilled the same on the rear no matter what it's from. Just use the adapter plate from your engine and it will work fine.
Postby ahale2772 » Thu Nov 19, 2009 8:11 pm
thats what i was hoping to hear thanks
Postby cumminz90 » Fri Nov 20, 2009 8:22 am
i just put a 727 behind mine and it came out of a f -700 ford everything went together like the old motr did hope that helps
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Postby ahale2772 » Fri Nov 20, 2009 8:31 am
was the motor p pumped?
Postby cumminz90 » Sun Nov 22, 2009 8:55 am
yea it was p pumped i believe its the 190 horse pump
cumminz90
Users browsing this forum: No registered users and 53 guests
