Home made water injection
Postby Fnschlaud4620 » Mon Apr 23, 2007 12:36 pm
well I found this on ebayhttp://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=019&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=290108558442&rd=1&rd=1
That got me thinking, I have old gm 6.2 and 6.5 starters at home?
I also got an old pressure washer pump, That will go from 200 to 1500 psi.
I have done a little research on tdr and sounds like 4 injectors in the intake and 2 in the charge pipe close to the outlet of the charger @600psi can get the job done!
The only other info I need is What size holes for jets?
I think this way I dont have to mess with an intercooler for the summer, and I can cool some of my air too.
Thanks
Fnschlaud
Fnschlaud4620
Postby Begle1 » Mon Apr 23, 2007 3:02 pm
Is that a starter motor? I would think that one could work... I've heard of people doing the homemade injections for cheap before, but I don't know what sort of pumps they used.
I think that the nozzle is just a hole. #8 is probably the drill bit size; it says it flows 1.5 quarts in 15 seconds, so I think it's pretty large.
I like the idea of a pressure-washed pump. I think that I've seen el-cheapo electric powerwashers at Harbor Freight for around $140... Or I could find a gas powered one that could fit where my air conditioner once went...
I really need to start researching my home-made water injection set-up too. I'm thinking about getting some chem-lab equipment to plug into my laptop, to read electric throttle position, EGT's and boost, and then have an Excel spreadsheet control an electric powerwasher accordingly.
A smart person could probably get a $2000 CoolingMist system for $400. I just need to find a smart person...
Postby 93 dually » Wed Jun 13, 2007 11:38 pm
devils own makes i nice water injection set up for around 360.00 plus tax www.devilsown.com
1993 d 350 htt turbo 5in stacks high flow intake .butchered fuel pin
93 dually
Postby CAJUN 93 » Thu Jun 14, 2007 5:58 am
linky no worky.....try this one
http://www.alcohol-injection.com/
daryl
after inspection.. looks to be more gas oriented. will the system work on a diesel?
CAJUN 93
Postby seeker1056 » Fri Jun 15, 2007 4:06 am
i am usin a walbro inline fuel pump as the water pressure pump, and a 12v startup injector for a VW as the nozzle and the washer bottle as a supply- works very well - total cost about a hundred bucks.
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby 93 dually » Mon Jun 18, 2007 3:43 am
need to go in their universal kits they make a kit just for diesels
93 dually
Postby CAJUN 93 » Mon Jun 18, 2007 6:13 am
yep, i see it now. thanks.
daryl
CAJUN 93
