DDP stage 4 injectors
Postby jwatso8 » Wed Nov 25, 2009 11:27 pm
i need help, i got a 92 I/C D250, play toy ONLY with DDP stg 4 injectors, air dog100 w/15psi, pump 3 turns on fuel screw, starwheel turned 1.5 times, dennyT fuel pin, custom air intake, S300 62/65/12 love it :lol: , coolertubz and 4" D/P and 5" stacks. 518 auto "stock" :cry: 32psi boost and 950EGT at WOT
my problem is before i put the injectors in the truck ran smooth in neutral and in drive. now that i replaced the injectors. it idles smooth in neutral, when i put in drive, i can hear a loping in the exhaust, at spot lights. but runs strong to WOT. i bumped my timing to 1.46mm, helping a little. i also adjusted valves, not to far off. but my real question is it normal to have a little lope with bigger injectors, with my set up. or am i just worried? also i put the truck in drive [setting the brakes] with it loping and did a cylinder cut out test on the injectors, all made a differance in idle speed.
i was thanking, the stock sticks were 5 holes and the DDP's were 4 hole. you thank it could have something to do with it. like maybe spray angles are different, or maybe the DDP's dont like the combustion chamber design/swril. or do you thank the pump is getting weak? if you give it a little throttle when it loping it smooths out. pop pressure on DDP's set at 245bar
i really dont thank the DDP's made that much more power, i thank, i want to go bigger. i was thanking about 6x16, but if i should stick with 5 hole injectors, 5x17 or 5x18? does anyone know were i can get some custom injectors and prices?
thanks for the help and sorry so long
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby soggy » Thu Nov 26, 2009 11:21 am
Sometimes when people switch to larger injectors it drops their idle, sounds like you just need to bump that back up a little. I know when i put the 6x16s in i lost 150 or so rpms at idle. I'm not too sure why it happens, maybe someone else will chime in.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby unixcowboy » Thu Nov 26, 2009 4:05 pm
I'm not an injector guru, but I'd suspect that the larger holes are allowing the internal pressure to bleed off quicker thereby the injector closes slightly earlier = slightly less fuel = slightly lower idle.
At higher engine speed the pressures are higher and the injectors are flowing more fuel = more power.
Just a guess...
Soggy - How do you like your M3 pin?
I'm debating on getting the M2 - or M3 . Not sure yet which,
'93 D250 CC 47RH w/goodies HX-40 60/65/17 w/hx50 flange 55 psi CoolerTubZ 6x16's M2 pin, 4"dp->5" pipe->5" Stack, PS IC
unixcowboy
Postby soggy » Thu Nov 26, 2009 11:14 pm
Well i had the afc lever removed before i put it in so i cant really compare it to a dennyt or anything, but I like it. The profile allows the fuel to come on more gradually which is a must with big sticks like we're running. Of course you know all that tho... I think i would go with an M2 to reduce low boost fueling even more if i was to do it again.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby cumminz90 » Sun Nov 29, 2009 8:28 am
Hope this helps when i put my DD4s in my 90 truck before i p pumped it they lowered the idleing rpm down a great deal had turn the fuel screw up a little bit more to get it back to normal. :grin:
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Users browsing this forum: No registered users and 63 guests
