Begle1 wrote:What's a cometic headgasket?
Does that mean that it comes all pretty looking with lip-stick and mascara?
KTA wrote:The problem with cometic gaskets is the requirments for the sealing surfaces. If you blow a stocker and put a cometic on without machining both surfaces it wont work. They would be awesome for an initial build, but not as a retrofit.
