Diesel Pump ????
Diesel Pump ????
Postby dakota farmer » Sun Nov 29, 2009 11:43 pm
This may be a stupid question? If i have a denny t pin in>>>>>>>> will the smoke screw still have affect on the pump. What is the best position for the smoke screw. Thanks guys.
93 350 Denny T./ 4 Turns Fuel Screw/ 3200 Spring......Still Looking for more to do.
dakota farmer
Postby peobryant » Mon Nov 30, 2009 12:01 am
Yeah, the smoke screw will still have an effect. If you want smoke, then you turn the screw in, however, I dislike smoke, so I'd either leave it stock (mine is) or back it out.
Postby dakota farmer » Mon Nov 30, 2009 6:48 am
Ok Thanks for the headsup..... I don't need more smoke just curious if there was any power advantage. Thanks again.
dakota farmer
Postby dakota farmer » Mon Nov 30, 2009 2:38 pm
Will you lose more power if you turn the smoke screw in too far. I understand the EGT problems. But I was just playing with the smoke screw on the pump and trying different settings and it seemed as if the truck had more power at the initial setting than it did when I turned it in 2 times. Just curious, it smoked more and that means more fuel...just seemed doggy.
dakota farmer
Postby peobryant » Mon Nov 30, 2009 3:42 pm
Don't quote me, but I believe the smoke screw controls how much fuel you get in a low boost situation. So by turning the screw in, when you aren't making boost, it will dump fuel in, essentially putting out the fire, making the truck slower.
Someone smarter than me can give you more information though.
Postby Richie O » Mon Nov 30, 2009 6:48 pm
It depends on the injector size. With stock intercooled sticks its pretty hard to overfuel at any boost level.
Postby TWorline » Mon Nov 30, 2009 7:03 pm
If you still have the stock turbo and esp. the stock exhaust housing you will definitely notice some lag before the turbo spools. The smoke screw preloads the fuel cone lower in the bore hence more fuel at idle and above till the turbo catches up i.e. spools up, providing more air and boost which works against the diaphragm pushing the cone farther into the bore giving you more fuel, get the picture? ;)
Tim Worline
http://www.CoolerTubz.com/
TWorline
Here ya go
Postby ZSkibo » Tue Dec 01, 2009 11:07 am
If you think about your fuel pin and it's relationship to the smoke screw it's not that complicated. Your fuel pin has a profile that determines fueling via boost produced. As boost increases the fuel pin is pushed down by the diaphragm thereby increasing fuel to the engine. That said, the "smoke screw" preloads the diaphragm in a downward fashion thus increasing preload fuel. Basically, it advances the fuel pins curve prior to your engine demanding any fuel, which is why it makes more smoke prior to the turbo coming on. The fuel pin and the smoke screw work together, as does the star wheel, all of which act on your AFC lever. Now, if you don't run your AFC like I do, none of this matter anymore. haha.. :P
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
Postby dakota farmer » Wed Dec 02, 2009 9:18 am
Thanks for the Heads up guys. I really appreciate the information. All the guys in this site have really helped get this truck running pretty hard for the time and money that I have invested, which isn't alot at this time. Thanks again.
dakota farmer
