Need help with gauges
Postby KGreen » Wed Dec 02, 2009 7:08 am
Hello everybody. I recently bought a intercooled 1991 Dodge Ram dually from my sister and have some questions. She bought them from genosgarage but never installed them because she kept the truck stock. here are the links to the ones she bought.
http://www.genosgarage.com/prodinfo.asp ... SS-R3607GR
she also let me have a 4 gauge pod that mounts on the dash. My question for you guys is what tools do I need to do this job? and if she doesn't have the tools, are they special ones or wil any place like home depot or sears have them?
thank you again everybody, you are helping me more than you know.
KGreen
Postby KGreen » Wed Dec 02, 2009 7:10 am
KGreen
Each of those is a project
Postby ZSkibo » Wed Dec 02, 2009 10:48 am
Boost is the eastiest to install. To get your egt in you have to drill and tap the manifold which is not that big a deal. Tranny temp needs a sensor installed in the PTO cover or pan, also not that big a deal. I forget what the other was but all in all it's just time and running wires. You can look on here for install on each. As for tools, nothing special comes to mind. If you are not mechanically adept, have someone show you.
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
Postby PToombs » Wed Dec 02, 2009 6:21 pm
Since you're close, you can have Parker give you a hand. He's not much on work, but he can guzzle beer and point to the things you did wrong. ;)
:jumpsmile:
Users browsing this forum: No registered users and 62 guests
