Lucas wrote:pdr pin works
but if you have the skills do it yourself
peobryant wrote:Lucas wrote:pdr pin works
A ground stock cone won't be as aggressive as a DennyT. Plus, a nice clean stock cone makes for a nice present.
burnt_servo wrote: being able to grind deeper into the cone than the pin can travel doesn't gain you anything.
chico_mustangs wrote:What do you guys think of me taking my bully dog pin out and grinding it down closer to the denny T pin?
Lucas wrote:I personally think all the performance gain is in our heads. i had the stock pin at the "deepest" setting and then changed to the pdr pin ....witch my trained injection pump rebuild buddy laughed at
all i noticed power/performance wise is that it would smoke like a bastard from idle to WOT if i mashed it.
Lucas wrote:exactly. what i thought. iwas thinking why dont people just take it out.
I personally think all the performance gain is in our heads. i had the stock pin at the "deepest" setting and then changed to the pdr pin ....witch my trained injection pump rebuild buddy laughed at![]()
