ve front seal
ve front seal
Postby skilletky » Wed Dec 09, 2009 10:08 am
whats the best way to keep it in place? i am pondering on getting a 14mm head and i am gonna have to up the inlet pressure aint I?
skilletky
Postby ford69557ci » Wed Dec 09, 2009 5:04 pm
I had a grove machined where the seal goes and used a snap ring to keep mine in place. This setup will hold easily to 40 psi inlet pressure, but if ya get over that fuel can start seeping between the shaft and seal
ford69557ci
Postby skilletky » Thu Dec 10, 2009 10:33 am
thank you. now , i hear around that the 14mm head is not so reliable. is this only when it is used with the 4mm cam plate or just the head itself? this is my only vehical at the moment, so this worries me. my FASS is set at 16 psi. do i have to raise my pressure if i put a 14mm head on? as of right now the pressure stays at 15-16 psi no matter how hard i get on it? thanks in advance for any input!
skilletky
Postby ford69557ci » Thu Dec 10, 2009 11:59 am
The 14mm can be reliable if the pump is setup to run it. I think what has killed some of them is not enough fuel flow and to small of an injector. I have ran my test pump countless hours with no failure to the h&r. The 4mm camplate needs does not work correctly in our pumps without some mods. It will cause a severe defuel due to uncovering the spill port
ford69557ci
Postby matchew » Thu Dec 10, 2009 8:29 pm
I've had my Rocken Tech 14mm in and running for about 4 months...all seems good but I NEED injectors. I'm scared to death to turn my pump up because of the small (40+) injectors.
92 1 ton, 7" lift 37 military MT's on Hummer Alcoas, HE341, 4" downpipe to tailpipe, killer front bumper, 14mm H+R, +40 injectors, 03 dodge seats, loud tunes. 'Custom' Rustoleum paint.
matchew
Postby skilletky » Thu Dec 10, 2009 11:18 pm
what else needs to be done to the pump to run the 14mm? i am getting some 6x16's whether or not i get a 14mm.
skilletky
Postby ford69557ci » Sun Dec 13, 2009 2:27 pm
You can slap the head on a stock pump and it will work. If you want max performance there are tons of thing that need to be done inside the pump for better fuel flow
ford69557ci
Postby skilletky » Mon Dec 14, 2009 9:19 am
sorry for all the questions, but is there a thread with all the info i need to put a head on for max performance? i tired using the search function but had no luck with it.
skilletky
Postby Mark Nixon » Mon Dec 14, 2009 10:42 am
Never really done much with the I.P. in general, myself, but everything I am reading says you can do a whole lot of things before you "need" the 14mm head and rotor.
IIWM, I'd do the most you can with what you have and research for the next step up.
You might decide that enough is enough.
