oversized injector lines
Postby jwatso8 » Thu Dec 10, 2009 3:07 am
do they make over sized, preformed injector lines for the VE pumps? thanks :roll:
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby ford69557ci » Thu Dec 10, 2009 12:01 pm
Ya gotta have them custom made. i had a local shop do mine and they leaked and didnt fit right. I think columbus diesel can make them for you but they might be kinda expensive.
ford69557ci
PDR
Postby ZSkibo » Thu Dec 10, 2009 2:24 pm
PDR will make them for like $350 or so, stainless or mild steel. Just be aware that they will retard your timing so be prepared to jump a tooth to get back to where you were prior to install. I'm wanting a set of .093's to go with my 5x18's when they come in. I've also heard that the stainless lines are more prone to cracking than the mild steel versions.
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
Postby ford69557ci » Thu Dec 10, 2009 2:57 pm
Unless you are running a heavy modded 14mm pump, big sticks, and tryin to spin a bunch of rpm they are pretty much a waste if time. On my old 12mm pump they made a erratic idle.
ford69557ci
Postby Frosty828 » Thu Dec 10, 2009 5:44 pm
a lopy eratic idle?
1990 w250, savage motorsports pump tune, 4" lift, 37" goodyears, fender cut out flares, protech headach rack, 727, ZF-5 going in this summer, custom intake, custom exhaust, custom rear tube bumper, onboard air, and a couple other mods...
Frosty828
Postby jwatso8 » Thu Dec 10, 2009 5:55 pm
ZSkibo
be sure and tell me if you would, how you like your 5x18 injectors. i was thanking of sending in my stock injectors to get EDM's to 5x18. or going to buy some 6x16's. where are you getting them from? thanks.
i thank ill just wait untill i get my 14mm head and the larger injectors and the twins :lol:
jwatso8
Postby bgilbert » Fri Dec 11, 2009 10:06 am
I'd spend the money somewhere else. I don't have them, and don't intend on buying any.
Bill Gilbert
bgilbert
Postby ford69557ci » Sun Dec 13, 2009 2:21 pm
Yeah it was kinda of a lope but nothin like the monster pumps and the vp trucks
ford69557ci
Postby dpuckett » Sun Dec 13, 2009 7:39 pm
If you want bigger lines (at least on an IC'd truck) you can get a set of nonIC lines- I think they are 0.1mm or so bigger in diameter. That could be part of the reason the Big Power trucks started out sans intercooler.
DP
