where are you all gettin your turbos???
Postby 93bfarms » Wed Dec 23, 2009 8:35 pm
im lookin at the hx40 for an upgrade. got pump mods and experiencing turbo chatter. where are you all gettin yours at? and its a t4 flange correct? whats the best turbo setup for towin? thanks, jayare
93bfarms
Postby KTA » Wed Dec 23, 2009 9:03 pm
The stock turbo is a t3. There are both t3 and t4 flanged hx40's as well as several diffrent wheel sizes. I get my turbos through work. We are dealers for holset and borg warner.
Postby 93bfarms » Thu Dec 24, 2009 9:13 am
whats the good combo on wheels sizes and housing size? and what does one cost? thanks for the help. jayare
93bfarms
Postby KTA » Thu Dec 24, 2009 9:49 am
That depends on your power goal, your fueling, and the uses for your truck.
Postby 93bfarms » Thu Dec 24, 2009 11:29 am
its a dd and used on the farm. tows a bit.i really dont know the hp level i would like to be. as of now its p-pumped, self cut pin,screw turned.timin bump. and like i said im gettin turbo chatter.and it as a5 speed so i would like quicker spool.. thanks jayare
93bfarms
Postby KTA » Thu Dec 24, 2009 1:12 pm
Sorry. That doesn't make any sense. You lost me.
Postby ford69557ci » Thu Dec 24, 2009 1:42 pm
I would like one of these p pumps with fuel screws lol. That one lost me slightly.
ford69557ci
Postby Mark Nixon » Thu Dec 24, 2009 2:22 pm
93bfarms wrote:...as of now its p-pumped, self cut pin,screw turned.timin bump....jayare
Sure it's not a VE rotary pump?
Everything after "..it's p-pumped..." sounds suspiciously "VE-ish" to me. :lol:
Postby 93bfarms » Thu Dec 24, 2009 8:59 pm
sorry, talkin about the lift pump. its 2cd gen piston pump with fpr.i dont really know the power i want. i want good power to pull and keep the egts down.
93bfarms
Postby Remps » Thu Dec 24, 2009 10:48 pm
A PDR Super 40 with a 16cm housing (Not that I have any actual experience with one) would be an excellent towing turbo for the money.(1000ish new)Not the fastest spooling unit,but that isn't as important as exhaust flow for keeping temps down. Assuming that you have gauges,if not you should at LEAST get a pyrometer. It would help if you filled out your sig. (year,model,auto or manual,modifications,etc)
Users browsing this forum: No registered users and 65 guests
