making it smoke
making it smoke
Postby 91bluecummins » Sat Jan 02, 2010 2:33 pm
does unpluging the intercooler hose from the motor hurt the truck even if i filter the air coming in :scratch:
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Postby fatty » Sat Jan 02, 2010 2:47 pm
:roll: :roll:
Postby PToombs » Sat Jan 02, 2010 2:50 pm
Well, yeah! :roll: You won't get enough air and the EGT's will go thru the roof. Plus it won't have any power with not enough air to burn the fuel.
Postby fergavs » Sat Jan 02, 2010 2:52 pm
But yes it will smoke like a freight train if u do that. Have a go at it and let us know how it all works out lol. I here these pistons make great ash trays.
fergavs
Postby 91bluecummins » Sat Jan 02, 2010 3:12 pm
i was just going to do this for a night or two but not until i get gauges
91bluecummins
Postby IowaCummins » Sat Jan 02, 2010 3:43 pm
would that cause the turbo to over speed the shaft? with only exhust pressure i would think it would just spin like crazy
IowaCummins
Postby 91bluecummins » Sat Jan 02, 2010 4:22 pm
so dont try this is what yall saying
91bluecummins
Postby oldestof11 » Sat Jan 02, 2010 4:25 pm
Why wait until gauges?
Dont be dumb! The reason you need gauges is to watch the EGT's. With no air being FORCED in, they would skyrocket!
Lemme explain the litte (big) spinny thingy on the exhaust.
Hot air (exhaust) goes thru it and spins the fan. Now the fan pushes air into the engine, free of charge. Now you disconnect the intercooler line and NO air is going in, the engine now has to SUCK the air in.
Now for a free power mod for you, take a 1" rubber hose, run it from the cab to the air filter and blow into it. Maybe relieve the air inside you....
Postby Richie O » Sat Jan 02, 2010 4:32 pm
Get some gauges and then add power. Smoke will come with power. All our trucks smoke ( some more then others ) but that was not the goal. The goal is power, smoke is a side effect.
Postby 91bluecummins » Sat Jan 02, 2010 4:41 pm
right i understand someone told me to do that i was just checking with yall thanks
91bluecummins
Postby KTA » Sat Jan 02, 2010 10:53 pm
Want I like giving diesels abad name smoke? put a trash bag over your airfilter and tape it shut with duct tape. Then poke a little hole in it, should work great at making a smoke machine out of your truck. :roll:
Postby Richie O » Sun Jan 03, 2010 7:45 pm
As you can see, your not going to get much love asking how to make smoke. Don't get me wrong, my trucks smoke bad, its just not what we are about. ( well, sometimes tailgaters get the coal ) We try to be good when everyone is watching and roal smoke when we can get away with it.
Postby PToombs » Mon Jan 04, 2010 6:56 pm
Yeah, all you have to do is puke out tons of black smoke and the state assemblyman following you will be passing a law for mandatory emissions inspections. :cry:
That's how it happens too. The wrong person sees the wrong thing, and everybody gets boned.
I usually smoke tailgators. And my friends, who are usually tailgating! :lol: But they ain't right anyways! ;)
Postby lectro_static » Mon Jan 04, 2010 11:39 pm
kinda funny how the tailgaters will back off quickly when you are doing 30mph stuff it in 5th and floor it, well thats what I do atleast until I get some bigger injectors
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby Begle1 » Tue Jan 05, 2010 9:55 am
So do you guys think that you are ever going to melt a piston with no turbocharger attached, regardless of what the pyrometer may be reading?
