needing some black smoke
Postby 91bluecummins » Sat Jan 02, 2010 4:30 pm
i want my truck to black smoke only when i stomp in to it and not to smoke when im just driving the spec on how much to turn every thing would be nice like smoke screw, starwheel,Ect... but i want it to boil out the soot when i do stomp it
thank you
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Postby Richie O » Sat Jan 02, 2010 5:14 pm
Gauges first , or you will be walking. You can take your smoke screw all the way down and you will get a puff when you first hit it. It will clear up just as soon as your boost comes up.
Postby 91bluecummins » Sat Jan 02, 2010 8:25 pm
im know that i need gauges first im just going to get pyro and tubro how high should my turbo gauge be if i have a stock turbo 30 be alright or 60
91bluecummins
Postby Richie O » Sat Jan 02, 2010 8:33 pm
Get a 60. Both of mine are over 30.
Postby RSWORDS » Sun Jan 03, 2010 1:50 pm
Definatly get a 60, I started with a 30, maxed that after a month, got a 60 and now I can make it touch the peg on a good pull.
RSWORDS
Postby pitman » Sat Jan 09, 2010 9:58 am
If you want smoke on a budget, the best thing that I have done is get on diesel truck resource, look up denny t and buy a fuel pin from him. A denny t fuel pin is the best upgrade I have ever made it will straight up roll the coal then
Single wheel 4x4 3/4ton 5_speed cummins. 100 horse injectors. Denny t fuel pin. Raptor fuel system. 1/4inch afc boost lines.!!!17 years old and a proud contributor to global warming!!!
pitman
Postby peobryant » Thu Jan 14, 2010 4:59 pm
pitman wrote:If you want smoke on a budget, the best thing that I have done is get on diesel truck resource, look up denny t and buy a fuel pin from him. A denny t fuel pin is the best upgrade I have ever made it will straight up roll the coal then
Dennis has his own website now. www.dennytperformance.com
Postby doublel89 » Thu Jan 14, 2010 7:40 pm
I started with a 30 lb with my stock h1c, took the fuel pin out to screw around when trying it, got surprised when my first take off pegged the gauge.
91 3/4 Ton 4x4, 5.9 Cummins,DDP Fuel Pin I usually leave it out though, DDP 40 Horse Sticks, HX35W And 2nd Gen Intercooler, Single 5'' Trunout, NV5600 Swap, Dually Conversion, 3.08 Rear Gears, Soon A Custom Hauler Bed
doublel89
